X1-AC Solax
- Nov 8, 2022
- 3
Hi, recently installed the Solax X1-AC 3.6 and Triple 5.8 battery.
Works, shows no fault. Charges from grid to 100% and discharge 10%.
Problem is that the house loads are not using battery. Just racking up the house meter power.
On Self Use so battery should give priority to house loads..
Chint meter DDSU666-CT requires both meter and the black CT clamp but even the inverter manual does not show that setup and Solax says there is not a proper diagram. So yes, point CT towards the grid but does not show the location of the CT.
So I placed the CT live between house meter then the Chint modbus meter, then the charger AC inverter.
Solax no proper help or response regarding ‘house loads not being used by battery’. Frustrating as I do not want to export the full battery to the grid.
Did you have a number for Solax uk help?
Does anybody know why I cannot use the battery power for house loads?
The Growatt PV when sunny, will supply washing machine etc. without using a penny, so house meter reading stays still.
thanks, Steve
thanks, Steve
