I need to setup my system for USE battery mode instead of EG4 mode but I don’t know what settings to change and what the setting should be changed to. Can someone help? My setup is 4 inverters setup as two separate systems. Inv1&2 are split phase set to EG4 and USE for the master and slave and comm connected to the battery rack of six lifepower4 batteries. Inv3&4 will be set to split phase as well and connected to the same rack but not comm connected to inv1&2 or comm connected to the battery rack. So these need to be USE for both master and slave. Can someone help me with the settings?
More info…no ac in connected. Am set to SBU.
So I think I’ll set my priority to USB, since I’m not using AC IN, setting 12 and 13 should be irrelevant.
