ZPowers
I’m getting a well drilled at my off grid property and trying to figure out if i need to get a groundfos well pump or not. My driller says they use either flowise or groundfos. My system runs on a 6000xp with 8 x 400 watt panels and battery backup. If my inverter will handle the start up wattage and i’ll install a pressure tank then why wouldn’t a standard well system work? I’m not sure I understand the reasoning of getting a more solar specific well pump?
