garybryan33
NEC dictates DC circuits are to be in metal conduits within a structure. The IMO DC disconnect is Plastic/pvc, do I need to install these inside a metal enclosure?
I planned to mount 3 DC disconnects on top of a metal enclosure using chase nipples. Run my PV wire to the metal enclosure via a 1-inch EMT, wire the 3 DC disconnects, and back out the bottom of the enclosure to the inverter.
