Hi everyone
I'm going to add one more panel to already installed panels (9 panels and all connected in series).
The panels are of JA solar, Deep Blue 4.0, JAM66D42-580/MB bifacial N-type.
I'm unable to understand if I could hook the new panel with the existing panels in series or I have to make two strings of 5 panels each and parallel them..
Inverter Specs.
Nominal DC/Max DC= 360/500 VDC
Start up/Initial Feeding= 120/150 VDC
MPP range = 120-430 VDC
Max input Current= 27 A
No of tracker= 1
Panels specs are
VoC = 48.18
Vmp = 40.42
Isc = 15.21
Imp = 14.35
Temp Coefficient of Isc = +0.046%/°C
Temp Coefficient of Voc = -0.36%/°C
Minimum temperature that we encounter in winters is around 3°C while maximum temperature reaches 46°C in summer.
If anyone can tell if I hook all the panels in series, will the VOC of inverter be crossed of it will be in limits. And if make two strings of 5 panels each, will it exceed the Isc of inverter?
Inverter Specs.
No of tracker= 1
Panels specs are
VoC = 48.18
Vmp = 40.42
Isc = 15.21
Imp = 14.35
