skylimit22
Hi all,
Having learned a lot from the forum I finally put together my own installation. I have a Deye 8K inverter, 10kw solar farm and a DYI 16S energy storage using Eve 280ah cells and Seplos 2.0 BMS. Everything works as expected, I can store energy and release to the grid or to my local consumption.
In some rare cases (approximately 1 out of 100 commands sent to the inverter), I have observed issues between the Seplos BMS and the Deye inverter. This results in the system not charging or discharging as expected. Instead, the battery appears to supply low stable power (around 1.4-1.8 amps) to the inverter. Please refer to the example chart below, illustrating how the battery-supplied power defaults to around 1.7 amp (the blue line) and remains at that level until the system is restarted, all while the battery SOC continues to decline.
The problem can be resolved by restarting the inverter, after which the system resumes charging or discharging as expected. The commands for charging or discharging are sent directly from the inverter (I used scheduled time slots). I am using a communication cable linking the battery and the inverter through the CAN port.
I suspect that the issue may be attributed to either (a) fluctuations in the overall grid or (b) a combination of power consumption variations from local devices causing sudden changes in the home network or (c) high frequency fluctuations in DC cables between the inverter and BMS.
Anyone has experienced anything similar or has any thoughts to share? Much appreciated. Thank you!
