Hi all! I was wondering if anyone out there knew when to use which type of conduit? Right now I plan to have trunk cables land in a junction box either on the roof or on the facia board. From there I was planing to use Ultratite Liquidtight flexible pvc conduit to run from the junction box down to the combiner. Then across the outside wall to the disconnect switch next to the meter. from there inside to the main panel.
Is there anypart of this process where code says you have to use EMT vs PVC or some other kind of conduit im not even aware of?
Thanks to anyone that spends the time to read this!
