Charge controller current
Budsy
Lindell Beach
Hi I was watching Wills video of his 24 volt system with 4 x 100 ah batteries and a 2000 w inverter and a 40a cc. I am building a very similar system which contains 4 x 100 ah batteries wired to 24 volts (ssp) with 4 x 100w solar panels 18. And 5 roughly and I want to know if it’s safe to use 30 a cc and a 1500w 24v inverter?
Thank you
400W / 24V = 16.7A
A 30A charge controller can handle that fine.
You will be limited to about 2kWh of daily energy production in very favorable conditions.
24V/200Ah should be fine with a 1500W inverter. Many inverters specify a minimum recommended battery capacity.
If you're asking to go smaller, than that is fine, provided the equipment and wiring can handle it.
