Considering Solar kit from Canadian Solar Power Store - thoughts on kits vs own build?
Hi all, I have been hesitating on pulling the trigger for Solar at my offgrid. It seems to me in the three years since I started searching, kits have come a long way. I’m currently considering this kit: https://solarpowerstore.ca/products...grid-generator-etc-solar-cabin-kit-bunkie-kit
My power needs are lights, fridge, a tv, water pump, and the ability to charge all the kids devices. I assume a washer/dishwasher might be done in the future and want a system I can easily add to. What are your thoughts on kits like this? Pros and cons?
I was going to say “no.” But thekit looks pretty reasonable. Battery has a good rep. Panels are probably fine. Racking/mounting?
I don’t know anything about the inverter.
I’d wait a bit. The experts will be here shortly. Esp re Canada reqs
My opinion is it's a nice kit but overpriced quite a bit.
I'd try to find used panels locally (not sure how easy that is in Canada) and DIY a battery. You'll save enough money to double your battery capacity, easily.
Also it wouldn't hurt to see if current connected ships to Canada... Compare prices.
Not sure if you went with solarpowerstorecanada. My experience was terrible. Started the project May 2023 and it is not completed yet. They are only for buying solar parts but not for service. Their design was wrong, went through multiple changes during installation ,changed inverters and too many issues. Right now 4 panels off due to different position pulling down the current on other set of panels and yet to be fixed. Stickers are missing and ESA permit not issue yet.
Please do not buy any kind of service from them. As soon as they get money for their product, you are pretty much done. Zero technical support and after sales service.
There are 2-3 ways to go about your project.
First, do it on the cheap and purchase used parts where you can like panels and inverters, maybe even batteries.
Second, buy new products, but not the highest quality and not CSA or UL listed. This route often provides equipment of a lower quality and performance. It may work well or not and may present more of a fire risk or lower performance as well as less support from the manufacturer or seller. It will add less value.
Third, purchase first rate hardware that is CSA/UL listed. This will cost more, but not much more if you shop around. performance and support will be available and met. Duration will be the longest, fire risk the lowest and value added to your property the most. Worry when you are not the very low. Many of these solution allow remote control via wifi or cellular.
Now, question: Are you off grid in a place like Markham, ON or like Nunavut?
So what is the winter climate and summer climate, power needs in amps drawn by all connected devices and critical devices. Say the postal code would help location.
The best thing to do is to plan carefully. Write down what your performance expectations for your project are to be.
Write down your budget. Calculate your loads. Calculate your potential return on investment either by not having a diesel generator and fuel as primary power source. Know your expectations. Also figure out upon your expected or unexpected death, who will assume responsibility for the care, operation and maintenance of the system.
If you do this all first, rather than just buy a kit you saw online, you will get a much better final result.
Lastly, inverters are basically high frequency and low frequency. The low frequency use transformers to produce the output voltages, the high frequency models use high frequency electronic parts to produce the voltages. Low frequency inverters are old school, but run loads with larger inductive currents, like starting a motor would pose (blower motor, saw motor, etc.). This might be important to you in that off grid location.
So do some homework and lets follow up.
