SunBandit
![1715665430994.png 1715665430994.png](https://diysolarforum.com/data/attachments/215/215277-abd7218734da213688bade73549549c9.jpg)
The picture is hopefully somewhat self-explanatory. 12 Silfab 500watt panels. Trying to achieve minimal shading. Two strings going into an EG4 6000XP. I did some math and figured out shadow lengths at the winter and summer solstices to identify the best racking options. I also used the iron ridge tool to determine panel spacing. I created the strings based on likelihood of shading in the later afternoon in winter. String A should never see any shade. String B may see shading in winter in the early morning and late afternoon.
The sources of shade are:
- The AC unit is annoyingly right in the middle of things and will likely shade panel 6 from 2:30PM onward in winter.
- Late afternoon shade from trees to the south may get panels 10-12 even after I give them a shave this winter (which my neighbor very kindly agreed).
- I have a vent in front of panel 12 to shorten or bend after I talk to my general contractor.
Does this seem like a sensible plan? Should I be considering something else? What have I overlooked? Can I get any more panels up there that won't get shaded?
![Beaming face with smiling eyes :grin: 😁](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f601.png)
I haven't settled on the panels yet but figured higher wattage will maximize space and the Silfabs look like a good (albeit a little pricey) product.
- Power at Mpp: 500 Watts.
- Isc: 13.48 Amps.
- Voc: 45.78 Volts.
- Imp: 12.89 Amps.
- Vmp: 38.80 Volts.
- Efficiency: 21.0%
- Cell: 132 Half cells mono PERC.
- Maximum system voltage: 1500 Volts.
