poppunkboy
So I have a Renogy 200 Amp Core battery, Victron 100V/50A Charge controller, and Renogy battery monitor (RBM500). When I discharge the battery with a load, the monitor doesn't change its capacity percentage. It always stays at 99% or 100%, even after being discharged (anywhere from a few watts from my mini fridge or an 800 W appliance).
One time after about 2 cloudy days in LA, I used an 800-900 W appliance for 2 minutes and the battery monitor went from 100% to 0%. I turned things off and then started charging the battery again, afraid I fully discharged the battery, even though mathematically I don't think that was the case. I had only previously used the battery for charging my phone and running a mini fridge. A similar instance happened again a few days later, and I contacted Renogy to troubleshoot. I sent them back the battery monitor believing it was faulty. They haven't given me a test result back yet
Renogy sent another battery monitor of the same model to me & I still have the same issue. I even tried with the Renogy One Core & Smart Shunt. See video of me trying both monitoring set-ups. In another video, the One Core shows a voltage warning at 14.3 V when the voltage on my Victron charge controller's app was slightly different (14.2 V). I have had some random beeps happen from the smart shunt even after properly syncing SOC and such, which makes me wonder how accurate or "high-quality" Renogy products are...
Someone please tell me what I am doing wrong.... It's hard to believe 3 products wouldn't properly show the battery's capacity.
