tacomaguy20
So I live in Arizona and I wanted to hook up a hybrid system with batteries. My electrical panel faces west and is on the exterior side of my garage. It's a 3 car garage so pretty good size. I was going to install the inverter on the inside wall of the garage but it still gets to over 100 degrees in the garage during the summer (it's not insulated and actually vents to the outside in several locations). I think it vents because my Water Heater is gas and carbon monoxide buildup could be bad. Arizona regularly gets over 110 degrees outside during the summer. What are some options to keep my inverter + batteries cool? I thought of installing a large mini split in the garage but that may eat up quite a bit of my power. What are some other options? I thought about moving my inverter to my bedroom closet (which about 20 feet down that west wall along the south wall of the garage) but I'm not sure if that would be best. Any advice/recommendations appreciated.
