Will an additional inverter produce higher battery output?
N3WB0Y
UK
I currently have a Growatt SPH5000 inverter and the maximum power it pushes out from batteries is 3kW. Am I correct to think that if I purchase an additional Growatt SPH6000 inverter this’d give maximum power out at 7kW (3kW + 4kW in parallel)?
The purpose is to be able to slow charge an EV at max 7kW over long periods purely from battery.
I believe so. I currently have 2x Growatt GBLI6532 hooked “together” (serial) to act as one battery. Each GBLI6532 is supposed to be able to discharge at 5kW, so the existing 3kW max is imposed by the limit on the inverter.
Will an additional inverter (+4kW) be able to connect to a single battery, giving me 3 + 4 = 7kW I am after?
