Issues with Power Station I only Used Once
f-tx
NYC
I have a Delta Max 2000 that I have literally only used once. I left it at a 100% charge and must have forgot to long press the power button to completely turn it off. A few months later I plug it in and the screen comes up but I am getting 0 input from AC and the battery failure light is flashing. How do I bring this thing back to life? There must be some way to fix this I can't believe it could be bricked so easily.
Leave it plugged in for a bit. It may wake itself up after sufficient time with AC input.
Just so you are aware, I've seen where the input on my Delta 2 max shows as zero but it's actually taking 30+W input to balance the internal batteries, when looking at external load sensors. So don't necessarily believe what it says.
Phew! So just leave it plugged in for a couple of hours and hope for the best. Battery failure light comes on in this circumstance though? The only other weird thing it powers on sometimes stay on and I was able to update firmware. But then other times I plug it in and it turns on for a second and then immediately turns back off. Is that normal in this circumstance?
This is a hail Mary situation, only speculation on my part but knowing they can take power while showing zero. Leave it plugged in overnight and see where she is in the morning. Be careful doing any kind of firmware update when the battery is low.
