GummiSolar
- Feb 23, 2022
- 66
Looks like it is designed for two cables in parallel, only one burned up.Beware of the APEXIUM BOX this happened with the connectors they proved with the box.
The connector is rated for 200A, It is a 50mm2 wire and the inverter was set to charge and discharge at a max 160A.Looks like it is designed for two cables in parallel, only one burned up.
Were you using two? If so, it possible the undamaged one has slightly higher resistance, so the other one took the hit.
How much current was going through there? 50mm^2 welding cable is rated for 255-345A depending on manufacturer.
Not clear what the connector is rated for, but I would guess 200A.
Hmmm... my schoolgirl maths tells me that a diameter of 50mm would be an area of 25*25*3.14 = 1962mm^2 - that's big!Looks like it says 50 mm on the cable side. Maybe thats a diameter and not an area.
Is it possible it wasn't fully seated/locked in?Beware of the APEXIUM BOX this happened with the connectors they proved with the box. Also I talked to Apexium and Jenny they were absolutely no help at all.View attachment 222832View attachment 222833View attachment 222834View attachment 222835View attachment 222836View attachment 222837View attachment 222838View attachment 222831View attachment 222832View attachment 222833View attachment 222834View attachment 222835View attachment 222836View attachment 222837View attachment 222838
Sounds too big. I really wish the vendors would publish the part numbers for these connectors.Hmmm... my schoolgirl maths tells me that a diameter of 50mm would be an area of 25*25*3.14 = 1962mm^2 - that's big!
I think the second connector is for daisy chaining a string of them in parallel.Looks like it is designed for two cables in parallel, only one burned up.
Ist not 50mm but 50mm2 .Sounds too big. I really wish the vendors would publish the part numbers for these connectors.
Maybe they couldn’t fit the 2 superscript for mm^2
I read the Apexium specs and manual and found nothing.
So I don’t know why the connector says 50mm.
Wow, sorry that happened.Beware of the APEXIUM BOX this happened with the connectors they proved with the box. Also I talked to Apexium and Jenny they were absolutely no help at all.View attachment 222832View attachment 222833View attachment 222834View attachment 222835View attachment 222836View attachment 222837View attachment 222838View attachment 222831View attachment 222832View attachment 222833View attachment 222834View attachment 222835View attachment 222836View attachment 222837View attachment 222838
For da love of gay electrons don’t bring up washers and connections again.Wow, sorry that happened.
Do you have any more photos of the back side with everything still connected?
Is that a washer?
They are happy to create resistance.For da love of gay electrons don’t bring up washers and connections again.
Thanks.Moved this to its own thread.
not really...Unless I am mistaking what the images are showing it looks like this right angle connector is designed for push on quick connect. If so that is a design connection fault area. Since the damage seems greatest at this connection zone, even thought there is also some damage at the bus bar bolt area, I would agree that this type and brand of connector should be avoided.
These no-name connectors are basically knock-offs of the Amphenol Industrial SurLok Plus series of connectors.Unless I am mistaking what the images are showing it looks like this right angle connector is designed for push on quick connect. If so that is a design connection fault area. Since the damage seems greatest at this connection zone, even thought there is also some damage at the bus bar bolt area, I would agree that this type and brand of connector should be avoided.
except.. they are not no-name ( in the seplos boxes), they are futronics , and are use in all BYD busses and cars, and they are certainly no knock-offsThese no-name connectors are basically knock-offs of the Amphenol Industrial SurLok Plus series of connectors.
It's difficult to trust the knockoffs, because I have yet to see a data sheet with full specifications.
Yes, I realize there is no choice when you buy the gear.
For reference, I use the Amphenol ones for my DIY stuff because I know the company stands behind them.
SurLok Plus™
The SurLok Plus™ Compression Lug is a field-installable, high-reliability solution surpassing traditional compression lugs. Designed for ease of use, it utilizes standard industry crimp, screw, and busbar termination methods, eliminating the need for specialized torque tools.amphenol-industrial.com
