Solarequine
Hi there! I have a 24 Volt Fan and a 24 Volt panel that are meant to go together. I have 2 12 Volt Batteries hooked together in a series to make 24 Volts. I have a 12/24 volt solar controller. Panel is going into controller. Batteries are going into controller but im not sure if I am wiring the batteries properly for it the controller. For a while it worked and then it fizzled out on me. Big thing is my controller will not show 24 V going through it. Only 13 volts and I am stuck on what I have done wrong!
Any ideas?
Than you!
Any ideas?
Than you!
