Hello, I've seen a few threads discussing the Renogy Battery monitor not displaying correctly but mine appears to be a slightly different fault.
It correctly displays the discharge loads, it also displays charging from the solar panels. However it doesn't seem to take into account any alternator charging, therefore over time it thinks the battery is just constantly reducing. When I check on the charge controller it tells me the battery goes up to 100% once I've ran the van for a little while. Currently having to manually set it back to full when I know the batteries are fully charged. I've done the standard checks and the inverter, batteries and charge controller all appear to be working correctly, which brings me to the battery monitor display.
Any help would be immensely appreciated! Thank you in advance.
Current set up: 2x Solar panels, Renogy: 40A MPPT Charge controller, Renogy: Battery Monitor, Renogy 60A DC-DC Battery Charger, 1x 100ah Battery, 2x 150ah Battery.
