Personally I use pzem power monitors with esphome to measure usage from the grid and almost every circuit in the house aswell as many appliances, it likey gives you much better data and better polling rates than any inverter could, such as power factors and frequency aswell as all the basic stuff V,A,W,Wh I think each one costs less than $10 including the esp.I’m planning 2-Sol Ark 15ks and want to get that info into Home Assistant. The main item I need is grid on or off. When the grid goes down, I need that info to trigger in HA load shedding to the span panel I plan to install. Can someone confirm you get that info in HA with the Solar Assistant and HA integration?
Yes I know Span can automate this, but only if you purchase the batteries they support. I’m trying to get around this limitation.
