That 28.8v is also assuming his cells are balanced.It has USE setting that looks like you can set to whatever voltages you want.
Would select USE and set boost to 28.8V, float to 27V. If you can set boost time as well, set to 30 minutes.
One run away cell combined with a poor BMS he may not get to above 27.6v before the BMS stops charging.
