I was thinking aluminum tape, but I felt like after a couple years of rain/sun/snow/repeat it might not do so well.You might try aluminum tape. I would also think a barrier material such as roofing Try-ply or Tyvex wrap would help.
It is hard to have anything last for several years exposed to the elements.I was thinking aluminum tape, but I felt like after a couple years of rain/sun/snow/repeat it might not do so well.
I was also thinking maybe some sort of all weather caulk. I was thinking about material expansion and contraction as well, how much will that come into play?
That looks good, i like it.I like this Butyl rubber tape. Never hardens. Stays flexible.
Professional Super Waterproof Tape, Aluminum Butyl Rubber Tape for Pipe/Metal/Rv | eBay
Material Butyl Rubber ,Aluminium Foil. Repeatedly press the butyl sealant until the tape is fully stuck with surface, Cut the butyl tape with a knife. ãPerfect PerformanceãOur aluminum butyl super waterproof seal duct tape is 48mil Thickness x 4" Width x 16.4' Length ( 1.2MM x 10CM x 5M )...www.ebay.com
DURABleTempered glass, EVA lamination andweatherproof backskin provide long-life andenhanced cell performance.
Typically, there is a thin gasket wrapped around the edge of the glass before the extruded aluminum frame is applied. It is somewhat adhesive. It is intended to keep water from getting under the frame, and probably , bonding the aluminum to the glass.That looks good, i like it.
The other question is the glass connected to the aluminum panel. From what I'm seeing, it looks like it.
Does that happen often?What is the game plan if one of the panels needs to be popped off for service?
Nope. I'm just going on a whim. I'm picking up steel hopefully tomorrow to build the frame, then just putting the panels on it. I'm overlapping the roof edge by about a foot. I'll post pictures of the project. My main concern is shade, but it would kind of be annoying to have it drip in the rain.If you have access from the bottom to do everything, probably not that often.
I was worried about it enough on roof to put all my microinverters in a readily accessible location.
What you're asking for is a pretty common dream, have you aggregated ideas and feedback from previous commentary on the web?
