timselectric
If I can do it, you can do it.
- Feb 5, 2022
- 20,135
Good catch.You probably need to turn that all off and wait until you have read the manual and understand what's going on. Those tiny wires are going to burn up in short order. You also need to find out what the current rating is on the tankless water heater and the pool pump.
They definitely aren't capable of carrying 50a. (Breaker size)
You don't have the correct size conductors.I also have everything in the off position; battery breaker, PV and the side Off and ON; I just plugged in the wifi doggle and am able to update the firmware. Sorry I usually take caution and rather talk to Signature Solar to do step by step; with dipsticks etc...
The breaker should be the weakest link, not the wire.
I'm guessing that the alarm is due to voltage drop on the tiny wires.
