BMS?
Mikendy
U.S.
Is a BMS required for both batteries if hooking a diy battery to the same parameters manufactured battery with a BMS?
You can avoid a second BMS by paralleling cells.
From experience, it sounds a lot easier than actually building it.
Cutting and tinning 9 extra busbars plus more fun. I recently turned 2 x 8s 25 ah packs tons to a single 2p8s 50 ah pack.
