I have a MPP Solar inverter (will did a review on this) its the 48V Hybrid system 5KW....
Just finished hooking up system and inverter is charging batts... I have 8 BANKS batts (all 12V AGM Gel batts)...
What should I set the inverter at for its MAX Charge ? I see on the BATT Meter it is at 56.9 Volts right now... I'm sure the one batt meter isnt exactly correct as it only says I have like 157AH but that isnt correct... as Each bank is 120ah (X 8 banks... should be 960AH)....
Also I was thinking MAX Charged voltage/float should be 13.8 per batt X 4.. which is.....55.2 volts.... correct ?
Attached is pics of the batt meters/ system.
Thanks in advance for any input...
