Dear all,
I just finished a small powerwall project that I am going to post soon. Before I write a post I would like to fully understand it. At this moment, I still have a question about the solar panel voltage and I hope you can help me.
I have a 10W (12V) solar panel placed in front of a window on a very cloudy day (no current production expected):
- The measured open voltage in that position is 16-17V approx. (specified at 18V).
- Whenever the panel is connected to a PWM controller that is yet not connected to a battery, the voltage from the panel goes down to 3,5V. The PWM remains off.
- Whenever the panel is connected to a PWM controller that is connected to a 13V battery, the voltage from the panel stays equal to the battery voltage (13V). The PWM is on.
I assume the lower panel voltage happens as result of the solar panel trying to feed the PWM; something that doesn't occur because the panel is not producing current at all. If I place a cloth on the panel and block the light, the voltage goes even lower (1,5V). So this part feels quite understood and clear.
I however fail to understand why is the voltage of the panel matching the voltage of the battery when the battery is also connected to the PWM. PWM should only act as a current valve and not modify panel voltage, right? My theory for this phenomenon is that the panel is trying to pull current to feed the battery but at no current, the voltage is going down. The reason why the voltage doesn't go below the battery voltage is because the consumption of the PWM is transferred to the battery and somehow the PWM is keeping the panel voltage at the battery voltage for (a) maximize current production given the near to zero panel output or (b) simply to keep the current from the battery to go to the panel.
My expectation is also that If the panel would be under the sun, then the panel voltage would go beyond the battery voltage and some current would start flowing into the battery too.
Could somebody help me understand what is happening?
Thanks a lot! Very appreciated.
Greetings.
Greetings.
