Hi,
Recently I installed a 5kw sola panel capacity with a Chinese SNADI MPPT charge controller (100A).
My battery bank is lithium 48V.
The system worked fine for few days then over suddenly it stopped charging.
I tried to disconnect and reconnect again, only to realize the solar charging controller remains at float charging stage and it doesn't go into bulk charging stage.
I have tried to reset settings to start afresh but results remain same. I also tried to change battery type without any success
I thought the problem was voltage settings. The float is set at 58.0V
Currently, the scc drains battery until it cuts off at 42V without charging.
I would like to get support
Thanks
Innocent (WhatsApp +255754711959)
Thanks
