Hi all,
I have a problem understanding how my MPPT charger works.
This is my setup ( 24V off-grid system):
- two 410W solar panels
- EaSun SMH 3k inverter with MPPT charger
- home built LiFePO4 7KW battery with JK BMS
According to the manual, the charger should use a 3 stage charging algorithm
The charger is in USER mode, bulk charging voltage is set to 27.4 V, float voltage to 26.5 V.
Also there is a small DC load connected to the battery, 15 to 100W. (battery heater, surveillance cameras )
However, this is what I see in a sunny day when the solar power is relatively constant:
1. Charger works normally in bulk mode, until the bulk charging voltage of 27.4 V is reached. At this point the battery is charging with more than 500W.
2. When 27.4 V is reached, the charger stops charging completely instead of switching to constant voltage mode.
SOC is about 98%, the battery can take more charging.
3. After 15-30 min battery voltage drops to ~26.7 V (above float voltage), then the charging resumes but this time pushing 10-50W instead of 500W.
It continues like this for the rest of the day, even though the panels can deliver 500-700W.
I don't understand why does it stop completely when it reaches 27.4V and why it's resuming charging with limited power.
When it resumes charging it's not using constant voltage of 27.4 V, nor it's in float mode because float starts at 26.5 V.
Instead it seems to aim for a small 0.4 A current, gradually increasing over a few hours to max 2 A, then gradually decreasing until the battery gets full.
Could somebody explain this?
