Hello. I am building a 16x 3.3V 280Ah Lifepo battery bank with REC-BMS connected to Victron Easysolar and GX. Everything is wired up, except I can't connect to the BMS since the wifi module is not detecting the BMS. However the display is working. I asked REC for help and we are figuring out how to make it work.
My question is. Can I leave the system on with the default BMS settings until we sort the connection problem? I believe that the default Chemistry is set to Li-ion instead of Lifepo. Will it damage the system?
Thanks a lot.
Thanks a lot.
