Hello, friends. My BMS is giving me errors and I have no idea why. My configuration: panels 13kwp, inverter Deye 16kw and 2 DIY batteries. Each battery has 16 cells EVE 280 and JK BMS PB2A16S15P. The inverter is configured to communicate with the BMS via CAN. The two BMS are connected in parallel and communicate with each other via RS485. All JK BMS have been updated to the latest firmware.
I did the system and BMS settings myself, but I am obviously missing something. I have been reading and educating myself on this for almost a month now, but to no avail. It's driving me crazy, I can't sleep peacefully, I would appreciate if you could help with any idea why I'm getting these errors.
Here is what I get.
1. In good weather the overcurrent protection is activated almost constantly. Sometimes only on the first bms, but almost always on both.
2. Sometimes a "PL Module Abnormal" error appears. Happens more often on the first bms, but very often on both.
3. Occasionally something called a "PCL Module" turns on, limiting the battery charge to 10A. I have no idea what this module does, how it turns on and off. This also happens more often on the first BMS.
Often the second battery manages to charge to 100%, while in the same time the first (where the errors occur more often) barely manages to charge 30-40%
Here are the BMS and inverter settings. At the bottom I will attach pictures with the errors I get.
The inverter understands when I make changes to the BMS settings, for example when I change the charge and discharge current in one of the BMS the changes are reflected on the inverter display. Also, if I stop the charge or discharge in one of the BMS settings, the inverter also changes the charge and discharge currents on its display.
Just in case I tried to further limit the charge and discharge currents through the inverter to 54A, while in the bms I set a limit of 60A, but again over current protection is triggered...
I don't have any more ideas, where I'm wrong and how to deal with these errors ...
Here is what I get.
