Adrian R
- Apr 14, 2021
- 69
Hey guys,
I have been using these Winston 400Ah LiYFePO4 batteries in an 8s configuration with electrodacus bms for about 4 years now.
Some people say these are the Ferrari s of lifepo4 because of the added yttrium.
However they don't come cheap.
Has anyone reviewed them? Do you know if Will did a review about Winston?
They go as big as 1000Ah!
And 3C continuous discharge rate, with 10C max discharge rate, and 3C charging current!
Another interesting thing is the weight of the Winston battery: for example, the 280Ah EVE battery is only 5,200 kg, and 260Ah (less capacity) Winston battery is 8,900 kg!
Some people say this is because all components of Winston are thicker and heavier and therefore last much longer! Winston claims at least 8000 cycles ...
shop.gwl.eu
ThunderSky WINSTON TSWB-LYP400AHA LiFeYPO4, 3.3V, 400Ah | GWL Group
High power lithium cell, original Winston Battery product with LiFePO4 (LiFeYPO4) technology. Capacity: 400Ah, size: 285x460x65 mm, weight: 13.7 kg. Model: WB-LYP400AHA(B)
