Hello,
I am working on small solar system for cameras and network equipment. I have a Victron 75/10 and it works well but I wanted to see if there are other controller options I may have missed. Below are my criteria.
Each camera will uses its own 50-160w solar panel and a LifePo4 battery. This will power a Ubiquiti Nanostation 5AC and a Dahua camera. I tried many configurations to get power usage as low as possible. Right now the complete setup averages 5.2Wh according to my watt meter. To get it this low the Dahua is powered via its 12v connection instead of PoE. Dahua says the 12v is +- 30% so running direct from battery is well within range. The Nanostation can be powered via 24v passive PoE or 36-48v Passive PoE. Both ranges use different PoE standards and therefore different wire pairs. The most efficient I have tested is the 24v using a $13 24v Supernight boost converter from amazon. To get dat remotely I am testing serial over tcp/ip.
- Small to fit a NEMA enclosure with battery
- LifePo4 compatible
- Load output control
- Serial interface for remote control & data
