TheDroidsYouAreLookingFor
- Dec 30, 2019
- 93
Another issue is your free Battery may have slowly sulphated to death. I mean at this point we have spoken on more solar, solar charge controllers, Diodes (including LED diode) and checking the actual current. Just to add something else to the mix I think you should upgrade the battery to LTO... (thats a joke) But really if battery voltage drops off right after the sun goes down or quickly after the panel loses sunlight the lead acid battery might be heading out to pasture so to speak. I personally hate motorcycle, lawn tractor and all those other expensive low capacity batteries that fail every winter on my motorcycles, sometimes even with a tender. I also think that the LED might have been whats called a "blocking Diode" they are used in solar panels so your panels don't become resisters overnight. I think someone was alluding to that above.
