Julianna
- Nov 11, 2021
- 18
I'm setting up a system to go in my shuttle bus conversion. I'm thinking about getting a 530w solar panel and 4 100ah 12v LIFEPO4 batteries to offset the high consumption I know the all in one systems have. I know the MPP LV2424 has a power saving setting but was wondering how effective it is? as well i was looking at the 3000w Growatt all in one system and was wondering if it had the same option? i also saw this HYBRID LV2424 – 24V 2.4kW system and was wondering if this would be better than the regular system? One of the things I'm worried about in the regular MPP LV2424 is that I saw in the specifications this unit is the only one made with a PWM instead of MTTP charge controller.
What system would you suggest? How would you rate these systems? Any info is appreciated, thanks.
