mystic pizza
- Jun 20, 2021
- 134
How many times did you have to cycle it to get the BMV to agree with the BMS?I am dealing with this right now, too. I'm running a 280ah battery with 800 watts solar, which should be adequate, but my weather has been crap lately, and I've only gotten a full charge once in two weeks. Compounded by the fact that I just took my whole system apart the other day, to switch things around and add my new victron scc, and both my monitors (jbd BMS and victron BMV 700) got reset. I just reset my bms, because it was showing only 40% and 90 ah remaining at 3.35 vpc. After reset, the soc was more in line with expectations. Bmv700 showed 270 ah remaining. Finally having some sun today, and battery#1 is at 3.31 vpc while battery #2(just built, not connected) is being charged by my power supply @10amps. BMV was recently reset, as I said, and is now indicating 254 remaining, while BMV shows 261 remaining. They seem to be more in line with expected numbers. Hopefully, #1 will reach 100% SOC by the end of the day. I'm shooting for top-off at 14v even. I'd like to get a good top and soak for my first cap test. Two hours until loss of sun for the day. I hope I get there. May have to stop charging#2.
I have a battery monitor too, but have largely been ignoring the SOC reading at this point as I understand it needs regular syncing.
