OK.... Thanks.
Both will work.
The non-Bluetooth will be set to a fairly low Low-voltage disconnect (LVD) and a fairly high high-voltage disconnect(HVD). If your loads and chargers all have LVD and HVD settings, they will be set to kick out before the battery BMS kicks out so unless there is a separate problem, the BMS should never have to disconnect.
The Bluetooth will give you a lot more data for things like cell voltages and a lot more settings of things like HVD and LVD.
Some people really like the ability to see all the data and tweak the settings so the Bluetooth is good for them.
Other people are less interested in this kind of insight and control, they just want to set up the system and forget about it.
When I first started with LiFePO I wanted all the control and data I could get..... but I have found that once a system is set up and working, I just don't check the data anymore. Frankly, the only time all the data is useful is if I am debugging a battery build, but with a pre-built battery that should be very uncommon. Furthermore, if it is still under warranty it does not matter..... just replace it.
So..... the question back at you is this: What kind of person are you. Do you like to tinker and get down in the minutia or do just want to build the system and be done with it?
