Yup, two versions, a zero turn faux commercial one, and a smaller riding style.Really?! Awesome! Didn't know they made one yet. Sweet!
Hey zamondo, I was looking into this exact question this past fall and I ultimately decided to build a 48v battery as others have done to save money and for the experience, but I was strongly considering going with a drop-in replacement as you're considering. For either drop-in replacement option (12v x 4 or 48v x 1) you won't need to replace the wiring harness or worry about additional cooling. The stock fuel gauge and charger should be replaced though. The stock battery meter / fuel gauge is a simple volt meter that converts the SLA voltage to a percent charge based on a look-up table and will be very inaccurate for LiFePo4 because the voltage-SOC curves are so different. A cheap and accurate fuel gauge can be purchased on Amazon but will require a little modding to install in the current panel. The new meter is a little bigger than the old. As for the stock charger, others here have gotten the stock charger to work with custom batteries. It likely will work with a drop-in replacement also but to maximize battery life you should get a charger that is designed for LiFePo4. The one I purchased is really robust, built like a tank. It cuts off once charging is complete (smart charger) and has a current adjustment knob that I've set to 15amps to not overwhelm the charger port wiring. It's not waterproof is the only negative I can see. I plan to move the charger cord from the old charger to use on the new one, which has screw terminals. Not yet sure if I'm going to have to install ring terminals on the old charger cable.Thank you AMDPower for starting this thread. Lots of great info. After reading everything, I ordered the Ryobi 42inch 100Ah zero-turn yesterday. I'm going to be mowing a lot of lawns with it so I needed to know I could replace the batteries and get more run time. Unfortunately I have neither the time or the expertise to build my own battery, but I don't mind paying for a drop-in solution. My question is, if I went with either 4 12v 100Ah in series or the single 48v 100Ah do I need to change the charger, cables, meter and add some kind of cooling or is it a true drop-in like so many of the batteries advertise. I'm a total noobie when it comes to this stuff. I really just need the easiest solution to get more daily run time. I think somebody mentioned that you would have to charge the 4 12v batteries with 4 separate chargers. I'm probably going to replace the batteries right away as I mow grass for a living and I just don't think the stock run time is going to cut it (pun intended). I was looking at the Mean Green mowers which claim a 7+ hour run time but would end up costing me about 13-14k to purchase and get out to Hawaii, so I can easily justify an extra 2-3k on top of the cost of the Ryobi. Any thoughts would be greatly appreciated.
It would be just my luck that Ryobi would come out with a lithium powered mower right after I by the older model. Its almost almost impossible to get anything lithium shipped to Hawaii, HD ships nothing out here… except the Zero Turn for some reason.My local home depot has lithium ryobi mower deck new on the lot, 3850...
I find the brushless term used on a mower to be funny...
Are you sure it's lithium-powered? I can't find any information online other than the AGM-powered ones (at the prices that you mentioned).My local home depot has lithium ryobi mower deck new on the lot, 3850...
Thank you for this info UltrasoundJelly, I like the idea of the single 48v, it sure is pricey. If I did choose to go with 4 separate 12v's for ease of installation, is there another option other than having 4 separate chargers to charge them equally each time? I'm guessing I would have to disconnect all the batteries that are connect in series each time I charge it if I had 4 seperate chargers, which really isn't an option. And if I can get them charged equally, would they discharge equally. It would suck to have one weak battery shutting me down prematurely. Maybe that's where some kind of charge controller comes in? And how bad is it if all the batteries don't charge equally I wonder. If I'm only loosing 20 minutes due to a premature shut down, but gaining an hour or more with the lithium setup, that's probably something I could live with... unless it's harming the batteries. One question about the Dakota 48v, it's rated at 96Au and AMDPower had mentioned his mower peaked at 100Au for a few seconds. Would that be an issue? Overall, I'm looking forward to doing this conversion. I'm thinking I may be able to use the batteries that I remove from the mower to build a little charging station on my trailer for my electric tools so they don't go to waste. Thanks again. The mower arrives around March 17th, so I've got a bit of time to work out the battery setup.Hey zamondo, I was looking into this exact question this past fall and I ultimately decided to build a 48v battery as others have done to save money and for the experience, but I was strongly considering going with a drop-in replacement as you're considering. For either drop-in replacement option (12v x 4 or 48v x 1) you won't need to replace the wiring harness or worry about additional cooling. The stock fuel gauge and charger should be replaced though. The stock battery meter / fuel gauge is a simple volt meter that converts the SLA voltage to a percent charge based on a look-up table and will be very inaccurate for LiFePo4 because the voltage-SOC curves are so different. A cheap and accurate fuel gauge can be purchased on Amazon but will require a little modding to install in the current panel. The new meter is a little bigger than the old. As for the stock charger, others here have gotten the stock charger to work with custom batteries. It likely will work with a drop-in replacement also but to maximize battery life you should get a charger that is designed for LiFePo4. The one I purchased is really robust, built like a tank. It cuts off once charging is complete (smart charger) and has a current adjustment knob that I've set to 15amps to not overwhelm the charger port wiring. It's not waterproof is the only negative I can see. I plan to move the charger cord from the old charger to use on the new one, which has screw terminals. Not yet sure if I'm going to have to install ring terminals on the old charger cable.
As for the 12v x 4 drop in option, this will be the easiest to install because the batteries are the same size but from what I've read you need to 1) ensure that they are rated for series installation and 2) you might not get the maximum power out of the bank because as you charge them the weakest battery could prematurely cut off further charging, and as your discharge them the weakest battery would cut out the bank early. There are a bunch of options for drop-in 12v replacements with widely varying prices and warranties. I didn't go too far down this rabbit hole, but there's so much competition here prices have gotten really good.
As for the 48v replacement, the biggest challenges here are 1) finding a replacement that fits in the space and 2) figuring out how to secure the battery to battery tray. I found two possible options for drop-in 48v batteries that'll fit: I've emailed Signature Solar re: this 48v battery that'll fit and they're telling me that it's more of a slow 'n steady style deep cycle battery that wouldn't work well for mowers. Kinda implied that they wouldn't honor a warranty if used this way. The second drop-in 48v I've found that fits is going to be the Dakota Lithium. It's the best option I've found but comes at a price premium of $2700. Nice warranty. Biggest issue purchasing this one is they frequently have delayed shipping (seems like a common theme for all LiFePo4 batteries that aren't 12v drop-ins). Securing this battery in place will be key, maybe some straps combined with a sticky rubber? The front and back battery tray clamps are adjustable so you could use them to minimize front-back movement.
Good luck and please post pictures once you've finished your install.
If you know your pack's capacity you can just enter that value as 100% without taking the pack all the way down.Just assembled a 100Ahr battery pack using batteryhookup's cells. (photo's later)
With DalyBMS.
Using the CON120AC36/48DC Aims charger. DigiKey 229$.
Am wondering about the simple capacity gauges that state you must deplete the battery to set the zero state voltage. Such as this one. https://www.amazon.com/gp/product/B08HWFPGL5/?tag=thingiverse09-20&th=1
Is there a method to fake the empty voltage without pulling the entire pack down?
Next I'm web surfing to find a compatible 3 pin plug/socket to use with my GE Electrak riders. Found it. Delta-Q. Pricey receptacle but fits.
Basically, I think this is the way I need to go, because I can't justify spending 1000 bucks on lead every 2 years, but is there a simple run down of parts that would be needed to do the simplest upgrade to LiFePo4 on this Mower, without getting a degree in electrical engineering?
Thank you to anyone that reads through this and answers. I also have a 21.6kW solar array that was installed last year, I look forward to reading through posts about DIY solar and am potentially interested in coming up with battery backup for my solar as well.
I’m about to try out the “simple way” I have no time to build my own battery. My mower is brand new, it’s actually still at HD, I’m going to pick it up tomorrow. I’m going to order 4 of these battery's, the total with tax is about $1600. https://amperetime.com/products/ampere-time-12v-100ah-lithium-lifepo4-batteryI am 100% new to this and this is my first post here. I have so many questions and maybe I should consult Prof. Google before I go asking them here.
I recently sent my Ryobi Zero Turn in to Home Depot (had to be shipped from WA to AZ) because I believed the blade motor controllers were malfunctioning. I could mow anywhere from 3 minutes to 15 minutes then the blades would cut off/stop moving and I still had full speed capability and no slow down in movement. So I got a call yesterday saying that the Batteries, which have about 20 hours of use, are bad and need to be replaced at a cost of $1100.00 or more. I requested that they look into the motor controllers, as I don't want to send it back for that issue.
the news of the bad batteries got me started looking into changing out my own batteries, then incidentally, over here to change to a different kind of battery.
I've read through this forum, and with all the talk of voltages, BMS's. battery charge balancing, special chargers, etc. . . I'm wondering if I am in over my head as I have not done this before. I have 3d printers, and done home electrical and I'm a decent DIYer, but if I undertook a thing like this, would I need to buy special equipment to test and charge batteries just for the install?
Some posts make it seem like I could purchase four 12v 100ah batteries, a LiFePo4 charger, and a new gauge, and I'd be set. But some posts make it seem like that is a terrible idea and it wouldn't work and I need to buy batteries from china, build boxes, buy various electronics and dedicate my life to charging and maintaining said batteries.
I'm eager to see this build as it sounds closer to what I'm more comfortable with and potentially easier to revert back to the old system if I need to send it in for an unrelated warranty issue as I have another year on the warranty... Are you at all worried about warranty issues with the conversion? I didn't really think about it when I purchased the mower, but I am more concerned about it now in the last year. Hopefully HD finds out if there is a motor controller issue and fixes that, and I can worry about battery replacement on my own time.I’m about to try out the “simple way” I have no time to build my own battery. My mower is brand new, it’s actually still at HD, I’m going to pick it up tomorrow. I’m going to order 4 of these battery's, the total with tax is about $1600. https://amperetime.com/products/ampere-time-12v-100ah-lithium-lifepo4-battery
They do free shipping and have a 3% off coupon. The battery has a built in BMS and they say they can run 4 in serial. Also the dimensions are the same as the OEM so it should be a drop in solution unless i’m missing something. The FAQs say it has a max 5120w load power. That would be the only thing i’m not sure of, what the mowers max load is, but I’m guessing it will be enough. I’m going to get a new charger and voltage meter as mentioned I should previously. Hopefully that is all I will need. I’m not sure how to wire up the charger snd meter yet, but I’m guessing it’ll be pretty straightforward. I’ll document the process and post here. I have to get the batteries shipped to a California address then shipped by boat to Hawaii so it may take about 3-4 weeks before I can do the swap.
That question there at the end I do not know how to answer, like where would I find that info? My system was not a DIY install, I'm running 54 Solaria 400w panels with 54 IQ7a Enphase micro inverters. I am on a Net Metering system/Model here in WA so battery backup would be mainly for power outages or offsetting my peak usage during the winter months. I'm currently in school for a Mechanical Engineering Degree as that more aligns with my interests, electrical engineering is definitely important and I'm sure I'll learn a little about it as schooling progresses, but it doesn't interest me as much.Earn the EE degree in your garage, cut your teeth on the LiFePO4 battery bank for mower, and you'll be ready to build the battery backup system.
A small battery backup system for phone/internet could be an off the shelf "Solar Generator", but if you want anything on the scale of whole house backup, on the order of 10kW to 20kW peak loads and several 10's of kWh of storage, DIY with individual cells is likely the lowest cost approach. 1000 bucks ain't nothing compared to a bank that size.
Although, there are alternatives. I use AGM for whole-house backup, and minimize what I power at night. During the day, my GT PV inverters can power everything in the house, and adjust their AC output up or down to match loads plus battery recharging requirements. Does your PV system do "frequency-watts" feature of UL-1741-SA? That is key to integrating with a battery inverter.
I'm very interested in not burning down my shed, or my house, while attempting to get a mower on a different battery system though.
I checked it several times. Maybe it was SMPS caps discharging, but they fried the hell outta my plug.Double-check polarity.
Wasn't his arcing issue on the AC plug? Just the usual input capacitors of SMPS?
It's a different charger. I can measure capacitance with my DMM, not sure the range.Same charger OP used or a different one?
If different, might have a bunch of caps his doesn't.
Maybe mower motor control has a bunch of caps.
Isolated from batteries and discharged, you could measure with a meter (if your DMM has capacitance range. But mine doesn't go high enough for my inverter.)
Or measure RC time constant with resistor and battery.
Could be you need a precharge circuit like the guys with lithium battery and inverter. In your case, since you have a plug, just SPST switch in series with a resistor across it.
Ah, so like this using a 20A panel mount Midnight breaker? What size resistor?In series with wire between charger and connector.
With switch open, plug in connector. Instead of high inrush current and a spark, lower current flows through resistor, gradually charging capacitors to match battery voltage. Then close switch (it has to be able to carry charge current). Then turn on charger (or plug into AC.)
The switch won't be used to make or break under load, so it just needs to carry current while connected.
There are a number of battery-disconnect switches, some rated up to 48V. Their current handling would be overkill for charge current. They typically are rated 48V max (or less), not enough to cover actual charging voltage of a 48V battery. But I think the distinction is just human safety, not technical capability; above that voltage, terminals are supposed to be inaccessible. Since your current draw is less, the cheap knockoff switches are probably good enough (For inverter loads, Blue Sea and others have quality switches.)
DC circuit breakers like from Midnight should fit the bill too.
