uxcell 2Pcs Aluminum Case Resistor 100W 1.5 Ohm Wirewound Yellow for LED Replacement Converter 100W 1.5RJ: Amazon.com: Industrial & Scientific
www.amazon.com
you could try two of those in parallel, instead of the light bulb, it will make a 0.75Ohm/200W resistor, that will gave you 0.75x14=10.5V drop on a 2P2S configuration of your panels, but also will use up to 150W that will be transformed in heat, so you may need to put them on a heatsink.
