I think once you guys start to solder your closed ended terminal, you won't look back! Been building cables that way for years. They run much cooler with the huge conductivity improvement.
What would you call "normal" solder?Just note that cables soldered with normal DIY solder used outdoors deteriorate VERY quickly.
Silver solder is the solution here I believe.
To be honest I just crimp most often now and cover with glue backed shrink tubing.
Electronic rosin core?
Acid core?
Plumbing lead solder?
Lead free?
95/5 tin/antimony?
Only a dozen? I'm guessing diameter isnt one of the distinctive features...LOL - I was thinking the same thing -- I must have a dozen different types of solder sitting here in front of me all being I guess, considered "normal" ...
Acid core?
Lead free?
95/5 tin/antimony?
I am an HVAC contractor... so I'm not quite sure the number of soldiers and brazing rods I have in my arsenal...
I am thinking staybright#8 would be a good solder to try...
Low melting point, high silver content, strong etc...
the problem i have is most big lugs have huge hole.
would love to find some that i can drill myself
For the record, we offer 4/0 lugs with a 5/16" hole, and generally speaking anything smaller than a 5/16" connection post isn't going to be rated to handle the current that you'll (presumably) be carrying with a 4/0 cable... dunno if that helps, it depends on what size holes you're needing, I guess.the problem i have is most big lugs have huge hole.
After you crimp that style, you use a torch and solder in thru the hole. Also have the heat shrink tubing come up over it and the end of shrinking, push it down over the hole.The terminal end in that picture is a TERRIBLE cheapo acid or moisture environment fail waiting to happen...
True.After you crimp that style, you use a torch and solder in thru the hole. Also have the heat shrink tubing come up over it and the end of shrinking, push it down over the hole.
I feel safe ordering wire lugs etc from TEMCo, either direct, Ebay or Amazon.
https://temcoindustrial.com/
When I was building coils for my Vape stuff, I got my Kanthal from them. It was a lot cheaper than buying at the Vape shops. If I need stuff right now, they're located 30 minutes from me.TEMCO is what I use ... never been disappointed
