Bluetti AC200MAX
I want to charge a Bluetti AC200MAX, for a short time (until I get my other 2 panels installed), with my existing solar system which consists of:
1. 2 ea. Renogy 100W x 12V solar panels, VOC- 22.5V hooked up in parallel
2. 2 ea. HQST 100W x 12V solar panels, VOC- 24.3V UNINSTALLED/yet to be installed
3. 1 ea. RICH SOLAR 40 Amp 12V/24V DC Input MPPT Solar Charge Controller
4. 1 ea. Zooms 12V 100Ah LiFePO4 Deep Cycle Battery, Rechargeable Lithium Iron Phosphate Battery
5. 1 ea. PowerTech ON PURE SINE WAVE Inverter 1000w Cont/2000w Peak, 12v Dc -120v Ac
The Bluetti AC200MAX FAQ says that it can be charged with:
"What kind of solar panel should I choose?
A: Total Open Circuit Voltage should be between 10V-145V. "
What I think I get out of this is that before I install the other 2 100W x 12V solar panels, I COULD charge
the AC200MAX with the 2 solar panels I have hooked up already...... am I correct ?
Also, once I connect the other 2 solar panels (for a total of 4 x 100W x 12V solar panels), it should be OK to use the DC to charge the AC200MAX as well as
using the 12V AC outlet (only use the DC or the AC when charging, not both) ?
