I am looking at the Bluetti AC300 with the 150 volt input max. I like this solution because it is just plug and play. I don't like the foldable panels though from the same manufacturer. I get that 150 volts input capacity means you can use other panels in series up to 150 volts and they list max as 2400 watts. Does that mean I can buy 6 panels that are 24v 320watt, wire them in series and plug them into this system with the correct adapter since that is 144 volts and still under 2400 watts? Or is that getting a little close to the 150v for comfort? I know with my little 100 watt system the 12 volt panel actually brings in more than 12 volts and it occurs to me that if the same is true of all panels, 144 listed volts could be over 150 actual volts.
