Could not find such experience in this forum and wanted to share it with you.
Yesterday my solar panels produced much less kWh for what a sunny day should be like. Also I realized that during the sunset the PV arrangement voltage was almost zero while at that moment should be at least 20-30% of the VOC.
This morning I disconnected both panels as the issue persisted. Both were giving the right VOC individually and also in series. Finally I discovered that the connection of one MC4 connector was failing. The three MC4 pair of connectors are just 3 months old, or said in another way, have been exposed to the outdoor environment for 3 months. Despite of this short time, they are all significantly corroded already. I presume corrosion has been the rootcause for one of the connectors to disconnect. I have solved the issue by pushing the connectors against each other and remaking the connection but I am quite sure this problematic will hit back in the near future.
I think it is already too late to apply an effective solution given that corrosion has already started/happened, but I will try to clean the corrosion by scratching the metallic elements in the connectors and cover the connectors with plastic foil to isolate them as much as possible from rain, wind, etc...
My connectors are from Aliexpress. Probably they aren't made of stainless steel.
