Is that blue wire connected to some 12v line or to the positive of the 48v battery?I've finished my build and successfully mowed my yard with the new battery. 100 Ah cells, 16s Overkill BMS. Mowed my entire yard 0.8 acre on 22° slope using 30% of the battery capacity (80% → 50% SOC). One nice thing: with the old SLA OEM setup the fuel gauge would swing 20-30% depending on whether the battery was under load ( voltage vs SOC lookup table I presume ). I never knew that the actual percent was with the SLAs. With the shunt it's really nice knowing the exact SOC.
Max current while mowing with the new battery 108 Amps as reported by Overkill app, which did make me a little nervous. It must've been very brief since the 100A OEM battery fuse didn't blow. My old OEM battery was the 70Ah SLA. It might be placebo effect, but the mower seems peppier going up hills (shedding almost 200 pounds of lead and having more max current to work with I presume). I noticed no difference in center of gravity change: the mower doesn't seem any more likely to tip.
Here's a full Tinkercad of my build. I've been keeping SOC max 80% for battery life. AIMS charger set to charge LiFePo4 @ 15 amps. Planning to add a mechanical timer, estimate how long it will take to reach ~80% and have it turn off after that duration.
- The design I used is a modded version of @rio 's brilliant build, here are the changes I made
- added the middle lid notch to accept the steel lid brace (rough cut using a jigsaw)
- used high quality 1/2" birch plywood for the sides and bottom, 3/4" for the lid and middle spacers
- box held together with #6 screws and waterproof wood glue
- middle spacers screwed into side
- outside finished with 3 coats of spar polyurethane
- 5 mm EVA foam (white Cosplay foam from Hobby Lobby) to pad the hold-down braces under the lid
- 3d printed shunt holder, dust cap and stabilizers for middle brace, and the mains dust cap
- used this enormous stepper bit to enlarge the hole for the shunt display, took 10 minutes with hand drill
- I destroyed my OEM charging port by plugging in the AIMS Charger the first time causing a large arc from (we suspect) the inrush current filling the charger capacitors from the battery. I have a complaint filed with AIMS Corp to see if this is normal. Here's how I repaired:
- removed OEM charger receptacle and plug
- replaced with Anderson SB50 plugs
- 3d modeled the receptacle to hold the SB50 onto the mower (see pics)
- connected the blue wire from the lockout circuit to battery positive, permanently disabling the lockout†
- going to build a $20 protection circuit to prevent this moving forward using a diode and resistor in parallel
- for now I have been disabling the battery using iOS app, then connecting AIMS charger, last turning battery on to charge without arcing
† With rio's help we reverse engineered the lockout circuit in case anyone wants to see how it works, and how I decided to connect the lockout circuit to battery positive, see pic.
Definitely not getting the thunk. Is that lockout circuit the black box thingy in ultras pics ?This may be related to the lockout circuit, similar to what happened to @UltrasoundJelly (see the bottom of post #338). When you turn the key, do you hear the lockout relay "thud"? If not, you might want to try bypassing the lockout circuit like he did.
I can't imagine this being related to the cell voltage over limit. I assume the BMS is just handling this as it should. And as you said, if you're measuring 54 volts in the pack then this is not a voltage issue (unless this voltage plummets when you're turning the key, which would indicate issues with the pack, but I would think this is unlikely).
Yeah. It has two connectors: one with 3 wires (yellow, black, red) going towards the instrument panel, and another one with a single blue wire going towards the charge port. What USJ did was disconnect the blue wire and connect it directly to battery positive (48v). This will permanently disable the lockout condition.Definitely not getting the thunk. Is that lockout circuit the black box thingy in ultras pics ?
Dang it. It’s because I was gonna use the blue connect to hook into my charger and so snipped that. As soon as I put the red wire back in there I get clunk. I need to find a local source for an Anderson type connector so I can put this red wire back in that loop and get my charger easily connected. Thanks for your guidanceYeah. It has two connectors: one with 3 wires (yellow, black, red) going towards the instrument panel, and another one with a single blue wire going towards the charge port. What USJ did was disconnect the blue wire and connect it directly to battery positive (48v). This will permanently disable the lockout condition.
Glad you figured it out. Here's where I sourced my Anderson connectors:Dang it. It’s because I was gonna use the blue connect to hook into my charger and so snipped that. As soon as I put the red wire back in there I get clunk. I need to find a local source for an Anderson type connector so I can put this red wire back in that loop and get my charger easily connected. Thanks for your guidance
Yes, Anderson.Hi all,
A lot of great info in here. I'd love to get my Ryobi converted. I'm trying to have someone build my battery with BMS. They have a few questions I hope someone here can help with:
The connector to the Mower is it an Anderson style?
What is the discharge current? 1C?
Thanks for any help
The dimensions aren't the same. I've been looking for a similar "drop in" solution. I have the 75AH version of the RYOBI ZTM. What I've found is the following:I’m about to try out the “simple way” I have no time to build my own battery. My mower is brand new, it’s actually still at HD, I’m going to pick it up tomorrow. I’m going to order 4 of these battery's, the total with tax is about $1600. https://amperetime.com/products/ampere-time-12v-100ah-lithium-lifepo4-battery
They do free shipping and have a 3% off coupon. The battery has a built in BMS and they say they can run 4 in serial. Also the dimensions are the same as the OEM so it should be a drop in solution unless i’m missing something. The FAQs say it has a max 5120w load power. That would be the only thing i’m not sure of, what the mowers max load is, but I’m guessing it will be enough. I’m going to get a new charger and voltage meter as mentioned I should previously. Hopefully that is all I will need. I’m not sure how to wire up the charger snd meter yet, but I’m guessing it’ll be pretty straightforward. I’ll document the process and post here. I have to get the batteries shipped to a California address then shipped by boat to Hawaii so it may take about 3-4 weeks before I can do the swap.
My thinking is to get the 30in 50ah. I only have like 1/2 acre. Run it until the batteries die and then get some LiFePo4 to go in it. I currently have 560ah 12v in my van with an electrodacus sbms.For those that have a ryobi electric mower, would you buy it again? My snapper finally gave out and I am looking into an electric mower. I actually went to get a cub cadet today and it would not even turn on (error codes) to get it loaded. So I returned it. This has me a little worried about electric, but I love the idea of it. Just curious about opinions since it seems like many of you have owned ryobi mowers for some time.
I have had 3 gas power riding mowers over the years and just got tired of maintaining them constantly. My wife is the one that does the mowing and she can be hard on them. But all the cleaning of carburetors, filters and fuel system in general, adjusting valves, adjusting/replacing belts, changing oil, even buying transporting gas got old...or I got old and I'm tired of doing it. She has really liked our Ryobi. The only complaint she has is waiting for the batteries to recharge before she can finish her mow. We successfully got 3 seasons out of the SLA batteries but someone unplugged the mower this winter and the batteries are now dead. One of them actually shows a negative charge...not sure how common that is.For those that have a ryobi electric mower, would you buy it again? My snapper finally gave out and I am looking into an electric mower. I actually went to get a cub cadet today and it would not even turn on (error codes) to get it loaded. So I returned it. This has me a little worried about electric, but I love the idea of it. Just curious about opinions since it seems like many of you have owned ryobi mowers for some time.
The Ampere Time 12v 100Ah LifePO4 batteries should fit in the mower fine, although I have not tried. If you look at the dimensions of the OEM 100Ah batteries for these mowers (Leoch LPC12-100) the dimensions are 13 x 6.81 x 8.66. Nearly identical to AT and many of the Amazon 12v 100Ah LifePO4 ones. The battery frame should have bars on the sides that can be adjusted to the length of the battery as seen in the photo. This was from a post in the first page of this thread.The dimensions aren't the same. I've been looking for a similar "drop in" solution. I have the 75AH version of the RYOBI ZTM. What I've found is the following:
OEM (Leoch LPC12-75): 10.2 x 6.61 x 8.43 inches
Ampere Time 12V 50Ah: 7.79 x 6.53 x 6.69 inches
Ampere Time 12V 100Ah: 13 x 6.82 x 8.48 inches
I was about to purchase 4 of the 100Ah versions and I started to look into how I could get them to fit... I'm not sure you can? I'd need almost 6 more inches in depth. I'd likely have to build something to replace the sled (that's assuming I had 6 inches of space available inside). Not sure I want to go that route when I can get the 50Ah and secure them on the provided sled with the RYOBI.
I've replaced the Leoch batteries 2x (once per year from RYOBI thankfully) and I'm done with this lawn mower if I can't find a better use. The batteries make me not like the mower. If I can solve the battery issue then I'll be thrilled
I have the 75Ah non-zero turn version and I am going on my 5th season still on the original SLA batteries. I would absolutely buy it again. I only have about 1/3 of an acre to mow so I hardly use any battery. I also use a PowerPulse Battery Maintainer and have a solar charge controller to keep the batteries topped off. I like to think all of this will help my batteries last as long as possible.For those that have a ryobi electric mower, would you buy it again? My snapper finally gave out and I am looking into an electric mower. I actually went to get a cub cadet today and it would not even turn on (error codes) to get it loaded. So I returned it. This has me a little worried about electric, but I love the idea of it. Just curious about opinions since it seems like many of you have owned ryobi mowers for some time.
I have the Ryobi 100ah zero turn and have been happy with it, actually surprised by how well it has performed for almost 3 years now. Range has decreased by about 1/3 and I'm considering LifePo4 replacements. I have 4 1/2 acres to mow and use the Ryobi along with other gas mowers to get it cut. I run the Ryobi till it tells me "you better get home" just about all the time, which isn't good for AGM batteries.For those that have a ryobi electric mower, would you buy it again? My snapper finally gave out and I am looking into an electric mower. I actually went to get a cub cadet today and it would not even turn on (error codes) to get it loaded. So I returned it. This has me a little worried about electric, but I love the idea of it. Just curious about opinions since it seems like many of you have owned ryobi mowers for some time.
Good question. I bought the 75 Ah version in May '20 for $3550 (got a slight discount because it was delayed shipping). I have 8/10 acre of grass to mow on a 15-18° grade (see pics). When I first got the mower I was fairly pleased with it. Full yard mow took about an hour and used 40-50% of the SLA battery capacity at 80°F. Mow quality was good, easy to maneuver. Biggest initial downside was all the skidding on the slope with the turf tires. Once I replaced them with some super lug tractor-style tires it ran like a beast. Much happier with the mower after that, but it did still feel sluggish going up the steep slope, running at about 1/3 speed despite having the control bars floored forward.For those that have a ryobi electric mower, would you buy it again? My snapper finally gave out and I am looking into an electric mower. I actually went to get a cub cadet today and it would not even turn on (error codes) to get it loaded. So I returned it. This has me a little worried about electric, but I love the idea of it. Just curious about opinions since it seems like many of you have owned ryobi mowers for some time.
Thanks for this. I have a relatively small yard less than half an acre. so I was planning to get the 50ah. We need to mower more so my wife can pull the lawn trailer around the yard. I thought I could get the 50ah ($2500) and use the sla as long as possible then slowly put money aside for the lithium upgrade. I have built numerous lifepo4 packs, so I don't really see it being an issue. By what I have been able to find, It seems as though ryobi mowers are much more reliable than some of the other brands. Cub Cadet for one has some serious issues. I have almost purchased two that had issues at the store.Good question. I bought the 75 Ah version in May '20 for $3550 (got a slight discount because it was delayed shipping). I have 8/10 acre of grass to mow on a 15-18° grade (see pics). When I first got the mower I was fairly pleased with it. Full yard mow took about an hour and used 40-50% of the SLA battery capacity at 80°F. Mow quality was good, easy to maneuver. Biggest initial downside was all the skidding on the slope with the turf tires. Once I replaced them with some super lug tractor-style tires it ran like a beast. Much happier with the mower after that, but it did still feel sluggish going up the steep slope, running at about 1/3 speed despite having the control bars floored forward.
By the end of the very first season I was seeing the remaining SLA capacity dip into the 40s and sometimes 30% range, so I decided to start splitting up the mowing over 2 days. I did this the entire second season to try to preserve the batteries, but despite my efforts the capacity really took a nosedive. By the end of season 2 I had to recharge twice for a single mow, so mowing over three days. With a total cost of $800 for SLA replacements it only made sense to pursue a lithium replacement. I think my total battery build + lithium charger was on the order of $1300 + my time. So getting close to $5k. I love the mower now. I use 30% of the capacity, and it zips up the hills with much more pep. It also feels great knowing the mods I did worked... but I do like to tinker.
If I were in the market now I would probably not get this mower, or any mower that uses SLA. I'd look for a mower in the $5k range with 70+ Ah lithium capacity. Ryobi vs Ego. Looks like the Ego is $5500 for 40 Ah, so not sure if that would cut it with me. Would be really tempted by the Ryobi Lithium version of this mower, but pricing not yet out. I'd never again consider a gasser.
