TorC Solar Enthusiast Joined Jan 13, 2022 Messages 514 Apr 25, 2022 #51 I'd add another reason to that: the AC waveform goes above the nominal voltage so the RMS voltage is the nominal. For a 120VAC circuit the peak voltage is about 169V. At 24V that's almost 34V peak.
L LywWyr Solar Enthusiast Joined Feb 14, 2022 Messages 191 Apr 25, 2022 #52 Mike 134 said: you sound like an outside wireman. Click to expand... Electrical contractor. We do everything from data and phone cables to medium volt transmission lines.
