On the blueprint page for the "400w w/ alternator charging" about 3/4 to the end, Will recommends installing 20-30 amp fuses on each panel before the branch connector:
"Because this blueprint unfortunately requires parallel connection of the solar panels (which I dislike, but the charge controller voltage is quite limited), then you need to add a inline mc4 fuse to your individual solar panels. This is not the case in series strings. But because this blueprint requires so many solar panels in parallel, adding a inline mc4 fuse is very smart to do."
Can someone explain this a bit more? The blueprint recommends an MPPT DC-DC charger (12v, 50a). If the charger is rated for 50a and I put 30a fuses on each panel, won't that allow 116a [(30-1)x4] to come through before a fuse is blown? At that point, won't the charger either break/overheat or render the fuses null with it's own safety features because there's 116a coming to a 50a charger?
Will also says to get 20-30a fuses, but when I click on the link to amazon, I have to chose 20 or 30...so which is it? Does it matter?
Sorry if this has been addressed already, I'm new and still wrapping my head around this stuff. Thanks for patience and to Will for making this stuff accessible.
