dankleinman
- Sep 25, 2021
- 72
Hello if have some relays from batteries in bought and swapped out the bms because I wanted to bed able to bluetooth the battery so I could see the voltage on my phone . I have 2 right now but will be dismanteling 12 more packs in a couple weeks .
specs here :
Thanks
Dan
specs here :
GV121BAX, Contactor SPST-NO, 200+ AMP, 12-100VDC, 12VDC Coil, 38cm Flying leads, IP67
Gigavac GV121BAX, Contactor SPST-NO, 200+ AMP, 12-100VDC, 12VDC Coil, 38cm Flying leads, IP67 Features Hermetically Sealed UL1604 for Class I & II Div 2 and Class III for use in hazardous locations IP67 - Temporary water immersion (30 Min) SAE J1171 External ignition protection ISO8846...
fastron.com.au
Thanks
Dan
