Solarhead1
- Jun 12, 2022
- 27
I seeThis may be because 2 of my four batteries had an alarm light. I think they were lower than the charge on the other 2. Setting 12 on inverter was set at 10%. Iam charging batteries. Alarms on the 2 batteries are off and fault 61 is gone on both. Fingers crossed. I will fully charge and check status in the morning. I will post results
I spoke with tech at SS and they said it was losses of communication with the batteries. The tech attributed this to the data cable being bad...we shall see......, mine charges for hours at a time no problems, then it randomly throws a 61 code. It does it everything it finishes charging the Batts.Ran all night from 10pm. Checked at 3am no faults. Checked at 8am both units fault 61. Signature solar needs to address this. Would also like to know exactly what a fault 61 is?
Are there any updates on this issue? Most are having problems and it doesn't seem to be the cord or connection.We have seen reports of this, and are investigating. We believe it may be an issue with the first set of communication cables that were produced. We will make a full forum post when we have a 100% solution.
I started a new post - but it appears for 90%+ it is the cable. For those getting the error when it reaches 100% we are awaiting an update from our engineering team. In those cases the unit still operates correctly, it just displays error 61 at sporadic times for an unknown reason.Are there any updates on this issue? Most are having problems and it doesn't seem to be the cord or connection.
@RichardfromEG4
