Anyone have a good method to limiting SoC? I've oversized my system by about 20%, and was thinking of invest that oversizing towards longevity, by not charging to 100% each time. This is on an RV/van, I have all three methods of charging, solar, alternator, and shore/generator. I'm planning on four drop-in 12v batteries in parallel, and each has it's own BMS that does not allow customization.
My thought was to use a single Victron Smart Battery Protect that takes all the positive cables from the chargers to the battery, and set overvoltage to ~13.2v. This way it will disconnect the charger(s) once it reaches about -85-90%, but not keep floating up to 13.6v. I'd also have a relay to bypass the protector in case I did want to bring it up to 100%.
I have no experience w/ the Victron Smart Battery Protect, so I'm just spitballing here. Any other thoughts are welcome.
