RichardMole
- Dec 6, 2022
- 15
I have a Solis RAI-3K-48ES-5G inverter connected to four Dyness 2.4kWH batteries. Also 9 PV panels connected to a Solaredge SE3000H grid connected inverter.
The Solis inverter is set in Self Use mode, so that it charges the batteries when there is sunlight and the PV panels are producing power via the Solaredge inverter.
I am seeing though that the Solis inverter also charges the batteries in brief bursts during the night (at 3 or 4 hour intervals). It carries on doing this through the day if there is no sunshine. It must be drawing the power for this from the mains.
I've attached part of a SolidCloud screenshot to show what is happening.
Is this normal?
Why does it happen?
And if it isn't normal, what should I do about it?
Is this normal?
Why does it happen?
