After I got the latest firmware a few days ago, I have new strange behavior with my inverter. the problem they were trying to solve is the one where my inverter is trying to feed back power to the utility grid even while my batteries are only 50-60% SOC. It will stop the PV from charging the batteries and just start exporting to the grid. And, yes, all of the settings are correct to prevent sell back.
So, now that the firmware has been upgrade, I have new weirdness. What happens now is that the inverter will stop taking power from the PV right in the middle of the morning when charging my batteries. I will hear it hard at work and check things out and the PV will only be sending like 2500watts to the batteries and all of the load will be provided by the utility power grid. Before this update, and according to the settings, the load should be provided first, then charging last. So, when this weirdness happens, I turn off the grid utility power (breaker) and then my PV magically start producing 8500watts to feed the grid AND charge the batteries at the same time. Previous to the firmware upgrade, this is always how it would happen (max power feeding load first and charging with what is left over).
I am fed up with this inverter. I can't go out of town and leave it running because I have NO idea what will happen while I'm gone. This morning we have a power outage. Because we have snow that is not going to stop for a couple days, I had turned the batteries and PV off and was just running on the grid power. BUT, then the power went off. So, I went back and turned on the batteries and PV so taht I can have backup power. The inverter is clicking on and off and when I look at the screen, it is trying very hard to pull power from the utility grid. I understood that if the grid goes down, the relay would kick in and the inverter would be disconnected from the grid power? But, the ready light kept clicking on and of and on and off. So, I threw the breaker on the utility power to make sure nothing dangerous happens. I don't trust this inverter at all.
