fromport
Solar Addict
What model SS inverter manual are you referring to?The manual from Signature Solar is the best I have seen but still very lacking.
The island setting would be a good thing to test. I have a feeling that not selected or having it selected for enable will both work.I think you want active Island enabled also? You don't want to feed grid when it goes down.
Grid% is irrelevant in your case where you are not feeding a panel before the MR. If you are feeding a main panel between meter and MR then the Grid% will limit what it feeds the main panel when it gets to, in your case 80%, capacity of the inverter.
Any inverter connected to the grid requires anti-islanding functionality.The island setting would be a good thing to test. I have a feeling that not selected or having it selected for enable will both work.
I do not think this is what you think it is , see above.I think you want active Island enabled also? You don't want to feed grid when it goes down.
I have been looking at and is basically is the general version I have from BlueSun (one of the OEM's) but with some screenshots of the display.The manual from Signature Solar is the best I have seen but still very lacking.
I put it enable and it worked. Thank you.
I put enable and it worked better. Thank you.Okay. I'll activate it and see what happens. I'll let you know tomorrow. Thank you
Yes, 55.2v charge, 46v low batt. dod 80% grid 95% offgridDid you make sure the voltage settings are right on lead acid? You would think it would be based off of voltage like you said in that mode
I clamped it near the meter breaker, arrows facing grid sideAre your CT going to the panel, or from the grid to the panel?
Mine does the same thing but when on peak shift. Self consume doesn’t do that for me.Is anyone else seeing this?
I put my MR on "self consume"
Today my battery charged up a lot (not to full) and when sun set, it started using the battery again until it hit the low limit setting.
When I look at the meter to the grid I see this (when it is dark outside, so no PV support)
It is pushing 700+ watt into the grid.
That is not what I would assume a setting with "self consume"
Is anyone else seeing this kind of behavior as well ?
Too popular to check the forum probably.Did people see this video of Will?
He had never heard of MegaRevo?
Never searched his own forum?![]()
ANTI REFLUX ?Some changes..
I was/am hoping that Signature Solar would have more pull as they get a few units out. Not sure how generous they will be with sharing firmware.Maybe Will can use his pull to get better software made since that was his biggest gripe in the video.
I also think money (== sales) is more effective.I was/am hoping that Signature Solar would have more pull as they get a few units out. Not sure how generous they will be with sharing firmware.
I have stuck with the parallel release also.
20220602.axf
v2411_para.out
Glad to see someone is in contact with them. I think this is what we need, providing feedback with real time results.
I feel if they get this firmware working better like a solarak or deye, they could charge a little more for the units and would be a solid contender in the US market for a cheaper price pointI also think money (== sales) is more effective.
I am still in contact with them, will keep you posted
it was handy to have it on the first page, otherwise i have to browse and search for itI'm not sure why that happens. Some days it works, some days it doesn't. I don't think it provides much helpful data that isn't shown elsewhere.
