I tried all but doesnt find a way to get the read on solar asistantYou can get the RS485 signal from the ethernet port I guess. Not sure if there is any suitable PC software.
Did you end up getting work on solar asistant ?@jsmetalcraft - you'll need to find a circular 4-pin adapter to plug into the slot where the Solarman (IGEN) stick-logger goes. Circular Connector: Pin 1 = Positive 5 Volts, Pin 2 = Ground, Pin 3 = RS485+, Pin 4 = RS485-. For the life of me, I can't find out what the spec of the adapter is to order one. You can then just use a Raspberry Pi or similar with the Waveshare RS485<->Ethernet adapter and pymodbus to hoover up all metrics from the Megarevo. Some folks have done some pretty neat graphing of the metrics.
I am still missing so much information , and my oem reseller is pushing MR to update their info but no response yet.Once the firmware upgrade enabled proper data collection using the WiFi dongle, I stayed with the pro.solarmanpv.com site.
Can you tell us your settings please ?My unit's been running in Peak Shift mode (or Weak Shift according to the display) for a few months now and has been doing the right thing.
Thank you for all your information/feedback!My battery at home right now is only 6kWh (going to switch to home-made 14kWh or just buy a 25kWh system).
I am very confused by the wording/settings in the menu of the MR.The chart below shows peak shift working. The battery gets recharged at midnight during low power time and grid power is used to drive the loads until the start of peak time at 7am, then the battery is used until the PV system recharges it and also powers the loads. The battery is not touched until there isn't enough PV in the evening. I've actually turned off grid usage until 9pm (mostly just to not use grid when the dishwasher is on after dinner).
I have the Work Mode set to Peak Shift with Time 1 and Time 2 set.
Time 1:
Charge Start: 00:00
Charge End: 07:00
Disc Start: 07:01
Disc End: 22:00
Time 2:
Charge Start: 11:01
Charge End: 17:00
Disc Start: 17:01
Disc End: 19:00
What I'd done is try to balance the charging with the TOU periods. Time 1 is saying charge from the grid between midnight and 7am and discharge time is 7am to 10pm (not 9pm as I said before). The Time 2 setting is saying that you can actually charge from the grid during mid-peak pricing (11am-5pm, peak being 7am-11am and 5pm-7pm) if you have to - but I've actually not seen that as yet (my loads aren't big enough).
The :01 times are necessary otherwise if you say, for example, Charge End: 07:00, Disc Start: 07:00 - then the unit just gets confused.
I did encounter some weird behaviour when I turned off anti-reverse and let the unit power the grid. The main AC and dryer are not powered by the Megarevo and when I did my test, the dryer was going. The unit kicked into high gear and the fans sounded like jet engines and the battery started dumping at 200A and triggered an overload warning. I'm not entirely sure why the battery was being used to power the grid. I know somebody mentioned it in an earlier thread (jsmetal maybe?) and perhaps that's why you need to dial back the percentage fed to the grid.
They just released support for megarevo 8k inverter. I was notified this morning:I tried all but doesnt find a way to get the read on solar asistant
Mine i just new they send a new firmware just 2 days ago.. i have talking with support because mine no matter what i do .. it doesnt read and charge the battery from PV .. all the time . Like yesterday was everything perfect and today nothing is change .. and it simply dont charge the battery from PV .. maybe tomoroow it works who knows .. mine is working offgrid but he only charge the battery from Pv like a surprise who know when .. i have plenty of battery that i can be 2 days wothout chargings. But i still not been able to find the setup that charge all the time with PV .... No matter what mode i use@daffyjoel - I was able to extract info from the ModBus registers and the RS485/Ethernet gateway, but the Home Assistant (https://www.home-assistant.io/) way would be much less work! In the threads there is a yaml file that defines the modbus registers and their English equivalents (p18/19) - fromport and NCSolarGarage talk about it.
Once the firmware upgrade enabled proper data collection using the WiFi dongle, I stayed with the pro.solarmanpv.com site. I'd like to do Home Assistant, it's just low on the list of priorities.
A few pages back there was a post about making setting in lead acid, then go back to lithium mode.Mine i just new they send a new firmware just 2 days ago.. i have talking with support because mine no matter what i do .. it doesnt read and charge the battery from PV .. all the time . Like yesterday was everything perfect and today nothing is change .. and it simply dont charge the battery from PV .. maybe tomoroow it works who knows .. mine is working offgrid but he only charge the battery from Pv like a surprise who know when .. i have plenty of battery that i can be 2 days wothout chargings. But i still not been able to find the setup that charge all the time with PV .... No matter what mode i use
I do that but in this firmware it reads the bms correctly when you go back to lithium you have to setup again so is reading good ..A few pages back there was a post about making setting in lead acid, then go back to lithium mode.
I only assume you are using lithium? Does the BMS communicate with MR? If no I think you have to use lead acid settings.
What version of firmware are you showing now that you have updated?
Yes but from what port they read and manage the MR because the main problem on that inverter is that you cant setup remotly and the app is crazy slow to readThey just released support for megarevo 8k inverter. I was notified this morning:
For some reason mine somedays doenst charge from pv... But i fix the problem that it goes to grid mine dont use grid now but before was staying on grid any time he wants .. i have the work mode self consume... But i have my question on how to setup the dod settings... Plus to let you know something that i found is that the charger setting on the batt setting is for the charger controller not AC charger .. check the anitecerse or arc ..*WHAT A MESS*
This morning I switched from self supply to Peak shift.
My ToU times:
peak power: 2pm-8pm
off peak power: 8PM -10PM & 8AM-2PM
super off peak: 10PM-8AM
I have 20kWh usable battery capacity. I limit battery charging to 100 amps x 51 volt (15S batteries) = 5100 Wh per hour charging.
I have set Dod to 20% so I will drain only 16kWh from the batteries max.
So I setup timer 1 like this:
Charge Start: 10:00
Charge End: 13:59
So my batteries will have 4 hours to charge them with 5.1Kw/h so with the rest of my PV setup should be able to charge completely from SOLAR.
On cloudy days I will charge from the grid at off peak power.
at 2pm my batteries were charged to 95% , nice
Disc Start: 14:00
Disc End: 20:00
That is my most expensive rate so I want to use that from my batteries.
I had to work so I left (i know, pretty dumb) and left early after changing the settings.
Well, this is what happened :
At 2PM it switched to discharging mode.
Since PV was going down, it supplemented what PV could not made from the batteries!
But why ?! The load was less than 1000 watt and the rest of available solar should have been exporting to the grid!
at 4:30 it was pulling almost 5kW AC from the batteries and feeding it into the grid
When I arrived home at 5:15 noticed it and quickly changed back to self supply mode.
Batteries are now discharged to 49% and will not be able to pull me through the night on the current charge.
So like the previous report, the inverter was powering 5KW to the grid. I assume that is related to the 100 amp CHARGING current limit I set.
My batteries & inverter could have done 8kW if needed.
This is all so weird, I have to think about this.
So far I am not overly impressed with the whole MR concept.
I am thinking about instead of getting a second one, getting one of the luxpower(or relabled GSL) 12k inverters.
What a bummer...
The raspberry pie app runs on an appliance connected directly to the inverter's communication port. It is not "online" like Solarman. Also, Solar Assistant is not for managing the inverter. It is for getting better data out of the inverter than what Solarman provides, which is laughable!Yes but from what port they read and manage the MR because the main problem on that inverter is that you cant setup remotly and the app is crazy slow to read
Megarevo and solarman app to be honest for an app like that it was better dont do nothing... this is the first inverter that i have that the app is just to see not to setup ...is like you said a crapThe raspberry pie app runs on an appliance connected directly to the inverter's communication port. It is not "online" like Solarman. Also, Solar Assistant is not for managing the inverter. It is for getting better data out of the inverter than what Solarman provides, which is laughable!
Solar Assistant has added support for Megarevo.@jsmetalcraft - you'll need to find a circular 4-pin adapter to plug into the slot where the Solarman (IGEN) stick-logger goes. Circular Connector: Pin 1 = Positive 5 Volts, Pin 2 = Ground, Pin 3 = RS485+, Pin 4 = RS485-. For the life of me, I can't find out what the spec of the adapter is to order one. You can then just use a Raspberry Pi or similar with the Waveshare RS485<->Ethernet adapter and pymodbus to hoover up all metrics from the Megarevo. Some folks have done some pretty neat graphing of the metrics.
Actually is Pin 1 = 5v, Pin 2= RS485_A, Pin 3= RS485_B, Pin 4 = GND@jsmetalcraft - you'll need to find a circular 4-pin adapter to plug into the slot where the Solarman (IGEN) stick-logger goes. Circular Connector: Pin 1 = Positive 5 Volts, Pin 2 = Ground, Pin 3 = RS485+, Pin 4 = RS485-. For the life of me, I can't find out what the spec of the adapter is to order one. You can then just use a Raspberry Pi or similar with the Waveshare RS485<->Ethernet adapter and pymodbus to hoover up all metrics from the Megarevo. Some folks have done some pretty neat graphing of the metrics.
